  • Jascha Friend
    #120720
    I have a big problem in IE 6.0 with the modul positions right ,left and ja-tab01. If you come to the site all shows ok for a moment. After a few seconds the modules on left/right etc. jump to the bottom onsite. If you switch to a next site all seems ok, after a few seconds the same effect shows?? Only the IE shows this effect, I have test it with Firefox (latest relesae) and Opera(latest release) with no problem…but please heav a look with IE IE 6.0.2800.1106……very bad effect?
    Link to our page deleted cause nobody gives support……..
    Does anyone have the same problems or a tip how to solve it?
    Jascha Friend
    #221724
    Thanx for no support!!
    Now I have change the template and maybe I will change the club too…>:(
    bigrk Friend
    #221814
    Post your url again and I will take a look. 🙂
    Jascha Friend
    #221815
    sorry it`s a live site and I think 1. now it looks better and 2. I would`nt change the look of our site again because of the problems with the IE 6.0. 😉
    But thanx for your time…
    teanau_tuiono Friend
    #236778
    ive got the same problem are there any solutions out there?
    kashxo Friend
    #236804
    Do you have live URL, teanau_tuiono?
    Menalto Friend
    #236837
    This problem can be beacouse you have a banner in banner position that is to wide or that you use something else than the ja-news module(it depends on what you use there), or that you have some images in the tabs modules that is to wide or in user5(below the tabs)
This topic contains 7 replies, has 5 voices, and was last updated by  Menalto 16 years, 10 months ago.
