May 6, 2008 at 1:02 pm #128258
I have this problem with my template when i use IE7, it is fine in FF. What can cause this problem?
Sherlock FriendSherlock
- 2478 times in 2162 posts
May 7, 2008 at 10:55 am #248073Hi Juniamission !
please view this thread http://www.joomlart.com/forums/topic/newflash-problems/ to consult fixed it .1 user says Thank You to Sherlock for this useful post
May 8, 2008 at 9:00 am #248178As you can see I also have this problem in the menue to the left. I can find this out?
May 9, 2008 at 4:39 am #248318Hi Juniamission !
I don’t show link page have obove problem. You can send that link.May 9, 2008 at 7:18 am #248332<em>@hainn84 52441 wrote:</em><blockquote>Hi hainn84 !
I don’t show link page have obove problem. You can send that link.</blockquote>
http://rensame.sc11.co.uk/
Here you have the problem, and it appear in IE7.July 9, 2008 at 5:18 pm #258820I have the same problem. Is this problem already solved?
mfcphil Friendmfcphil
- 388 times in 133 posts
July 9, 2008 at 7:31 pm #258840Just a thought but you could try to reduce the length of your text in the longer menus to see if this is not forcing an overlap 😉
July 9, 2008 at 7:54 pm #258842Thanks voor your help, but that don’t fix the problem
When you go to this site: http://rensame.sc11.co.uk/ en change the lettertype to the smallest one, the problem still remains…
July 10, 2008 at 5:03 am #258916Hi all !
Please try to do following way below :
Open template.css file in templates/ja_fagus/css folder , add following code to it :
ul.menu li {
display : block;
July 10, 2008 at 9:51 am #258978Which css file?
Do you mean the “template_css.css” and does it matter where you add the code?
July 11, 2008 at 1:29 am #259112Hi mfcphill !
You can chang it following way below :
Open template_css.css file in templates/ja_fagus/css folder , find following code section at about line 1041 :
#ja-containerwrap, #ja-containerwrap-cm, #ja-containerwrap-c, #ja-containerwrap-f {
padding:0pt;
change to :#ja-containerwrap, #ja-containerwrap-cm, #ja-containerwrap-c, #ja-containerwrap-f {
background:url(../images/);
padding:0pt;
then you find following code section at about line 1045 :
#ja-container {
padding:10px 0pt;
change to :
Code:
#ja-container {
padding:10px 0pt;
background:#464646 url(../images/body-bg.jpg) repeat-x scroll center top;
July 21, 2008 at 12:51 pm #261175Thanks for your solution. The image in the header is now good. But the menu’s still have black blocks, like you can see in post item #3 of this thread.
Thanks in advance,
This topic contains 14 replies, has 4 voices, and was last updated by ibb15 16 years, 4 months ago.
