September 17, 2008 at 12:59 am #133421
I installed teh quickstart for Lrix undera DevWeb folder in the root. The install went without errors and or incident. I deleted the installation folder, teh admin section is complete and works fine. When i go to the site it is blank whiteness. I am a bit miffed on what is going wrong. I installed the sample data which was confirmed in the initial install
Please advise.
JM
September 17, 2008 at 1:51 am #270923Have you gone to templates manger and made sure you have selected teline ii as your default template?
Just an obvious suggestion.
David Huston
Sherlock FriendSherlock
- 2478 times in 2162 posts
September 17, 2008 at 2:09 am #270929Hi paycheck !
Please send url of your site.September 17, 2008 at 5:08 am #270962<em>@hainn84 80370 wrote:</em><blockquote>Hi paycheck !
Please send url of your site.</blockquote>
http://74.220.219.52/~ochallow/DevWeb/That is the link. I have it under my root site, I created a new db and the install went flawless on the quickstart, I installed the sample data and deleted the installation folder. Again the administration section is fine, it is the site that is not working.
JM
September 17, 2008 at 6:34 am #270972Ok paycheck !
Please send me admin acc via pm , i will check it for you !September 17, 2008 at 10:42 pm #271078<em>@hainn84 80370 wrote:</em><blockquote>Hi paycheck !
Please send url of your site.</blockquote>I am using JA Latrix but yes I have and the link is http://74.220.219.52/~ochallow/DevWeb/
September 18, 2008 at 3:25 am #271099<em>@hainn84 80420 wrote:</em><blockquote>Ok paycheck !
Please send me admin acc via pm , i will check it for you !</blockquote>no, i need admin account to access to admin panel .
jimcapraro Friendjimcapraro
- September 2008
- 4 times in 1 posts
September 18, 2008 at 4:50 am #271104I am having the same exact problem with an installation of JA_iris
website is: http://joomla.greatersouthwest.org
September 18, 2008 at 7:17 am #271116Hi jimcapraro !
Please try to change permission of ja_iris folder. i have gone to admin in your site but can’t detect the problem .Sherlock FriendSherlock
September 19, 2008 at 3:32 am #271266Hi jimcapraro !
thanks for you help, but i haven’t detect the problem ,very very strange problem , if posible, please send FTP account via pm, i want to debug it.Sherlock FriendSherlock
September 20, 2008 at 1:38 am #271446Hi jimcapraro !
i can’t login to http://winscp.net/eng with the account what you sent for me ! Please check it again !jimcapraro Friendjimcapraro
- September 2008
September 20, 2008 at 10:32 am #271493hiann84,
the login credentials that I sent to you are for http://joomla.greatersouthwest.orgWinSCP is a secure ftp client, you don’t need to log in to WinSCP, you just download the FREE client here: http://winscp.net/eng/download.php and use it to access http://joomla.greatersouthwest.org
September 22, 2008 at 1:44 am #271616Hi jimcapraro !
Yes, i have used cuteFTP to connect to http://joomla.greatersouthwest.org , ,but can’t connect.jimcapraro Friendjimcapraro
- September 2008
September 22, 2008 at 2:48 am #271626don’t use cute ftp — use winscp you can download it here:
http://winscp.net/eng/download.phpmake sure the protocol is set to sftp
September 22, 2008 at 6:03 am #271641Hi jimcapraro !
sorry ,i have just accessed to your host but i can’t find source , where do you put it ? sorry , because this is first , i use winscp with linux host . -
This topic contains 22 replies, has 4 voices, and was last updated by jimcapraro 16 years, 3 months ago.
