jojo12 Friend
jojo12
- August 2010
- 4 times in 2 posts
January 12, 2013 at 2:39 pm #183895Hi,
normally I use j2.5 and ja_t3v2 then all uploaded images are in the articles.
But with j2.5 and ja_t3v3 the same images go in a modal window centered over the page. (see image)
How to change that. I think it’s not a problem of jce.
jojo12 Friendjojo12
- August 2010
January 12, 2013 at 4:12 pm #479496EDIT: it seems to be a problem with jce image insert. When I use image button, then the problem doesn’t exist.
wrong it seems it has to do with image when it’s too large, then it will be modal.jojo12 Friendjojo12
- August 2010
January 12, 2013 at 4:34 pm #479497It seems to be the modal problem. Why modal reacts like that
( I tried the tip wroted in an other post, but for the first look, it didn’t change anything.jojo12 Friendjojo12
- August 2010
January 14, 2013 at 7:12 am #479574I think I found the solution but I don’t know if this causes other problems:
I had to go to plugins/system/ja_t3v3/t3v3base/bootstrap£/less/modals.less
I exchanged line 25 from position: fixed; to: position: relative;is this ok?
Saguaros ModeratorSaguaros
January 15, 2013 at 10:29 am #479831Please describe steps by steps to reproduce that problem so that I can check and give you best solution
jojo12 Friendjojo12
- August 2010
January 19, 2013 at 7:26 am #480409<em>@Saguaros 355286 wrote:</em><blockquote>Please describe steps by steps to reproduce that problem so that I can check and give you best solution</blockquote>
In Joomla 2.5.8 in a article written by jce I have one or more fotos.
In some cases something makes gives those pictures a modul class, in some cases not.
For those in modul class, these pictures go in absolute position and behind each other at the top of the page and over all kind of stuff in the page.
I tried to give in modules.less the position “relative” like that it seems to work (but I don’t know, if this causes other problems?)
–> it’s good to make a modal windows, for example when I will look the picture big, but normal it causes problems.An other problem is, when I have more pictures in the same line, then the go behind each other, even in relative position. I have this problem not in ja_t3v2.
jojo12 Friendjojo12
- August 2010
January 20, 2013 at 9:21 am #480485In responsive for iphone the modal problem persists. There must be an other place to change fixed to relative, but I don’t know where.
Pity!Saguaros ModeratorSaguaros
January 22, 2013 at 4:14 am #480690Hi,
Which template are you using? You can try to make change in file: /templates/your_default_template/css/custom.css and make your change. This will help to override the property in core file and not be affected when you update JAT3 plugin.
jojo12 Friendjojo12
- August 2010
January 22, 2013 at 10:08 am #480752I am using ja_t3v3_blank for joomla2.5 using in joomla 2.5.8.
I found in less a solution.
I ask you, why .modal has always to be in position: fixed? When I change that to “relative”, then the problem is resolved. But I don’t know, which other problems this will cause.
And I don’t know how to put this in custom.css.
EDIT: wow, it’s so easy: I inserted in custom.css the following:
.modal {
position: relative;and the problem is resolved.
THANK YOU VERY MUCH!!!AuthorPostsViewing 9 posts - 1 through 9 (of 9 total)This topic contains 9 replies, has 2 voices, and was last updated by jojo12 11 years, 11 months ago.
Problem: in j2.5: images uploaded with jce sometimes modal sometimes normal
