  • rachidelbaji Friend
    #169164
    Hi, Please Help me to fixe this problem in internet explorer :
    Problem in Ja slideshow module on Internet explorer; BIG SPACE AFTER JA SLIDSHOW (show attached picture)
    i use Ja tline 4 . joomla 1.7
    http://www.fkihbensalah24.com
    Thanks for help!
    1. porbleme-on-internet-explorer
    rachidelbaji Friend
    #416018
    Moderator!!!! Please help me to fix this probleme!!!
    I m waiting your help…
    rachidelbaji Friend
    #416368
    3 day for my problem and no ansewer from moderator !!! i dont understand what happen for my question?? my problem its very difficult or what??
    jooservices Friend
    #417195
    I’ve just checked into your site with IE9 but have no see trouble.
    Would you mind let’s me know which IE version you are using ?
    Beside , for urgent case please use ticket system .
    Thank you
    Viet Vu
    rachidelbaji Friend
    #417357
    i m update slidshow module in my site from ja bistro.
    the module work fine on IE8 and IE9, but this module note showing on IE7.
    Thank you Jooservices
    Thnak you Joomlart.com
    jooservices Friend
    #417385
    let’s me inform this issue to dev team for checking.
    I’ll try to respond you as soon as possible.
    Thank you
    Viet Vu
    rachidelbaji Friend
    #417452
    I send you my ftp information for my site by PM.
    Thank you Jooservices for your help
    Here the same Probleme-question
    http://www.joomlart.com/forums/topic/i-post-question-3-day-ago-but-no-answer1/!!!
    jooservices Friend
    #418115
    Good news for you, the issue is fixed now! There was some problem with your layout file while you customized it.
    Viet Vu
    rachidelbaji Friend
    #419067
    Thank you..Problem fiexed.
    I have javascript errors , now i m fixed this problem after i upgrade all extension with JA Extension Manager >>
    Thankyou Joomlart
    jooservices Friend
    #419071
    You are most welcome 🙂
This topic contains 10 replies, has 2 voices, and was last updated by  jooservices 13 years, 2 months ago.
