June 17, 2017 at 2:54 pm #1042470
Hi there,
my site is in english ang greek language.
In Greek version drop down selection does not work either in front end and in the item extra field.Luna Garden ModeratorLuna Garden
- July 2011
- 453 times in 425 posts
June 19, 2017 at 3:16 am #1042625June 19, 2017 at 11:26 am #1042781Hi, finaly i solved the problem before I get your reply. But now I have another issue. The map in All in one map menu does not working and in Greek version desappeared. I thing I clicked in save button in System – JA Google Map plugin. Can you please help me?
- This reply was modified 7 years, 6 months ago by stampgo7.
- July 2011
June 20, 2017 at 10:37 am #1043000June 20, 2017 at 2:23 pm #1043036Hi again The map in All in one map menu does not work and in Greek version desappeared. I thing I clicked in save button in System – JA Google Map plugin. Can you please help me?
June 21, 2017 at 7:37 am #1043222Hi,
Check on your site to enable to show Longitude & Latitude Extra Field on JA K2 Filter ( you can check in JA K2 Filter component Option >> Extra-fields View Options
Hi again the problem I have is that the map in All in one map menu does not work and in Greek version desappeared. I thing I clicked in save button in System – JA Google Map plugin.
I noticed that the that the map in All in one map menu does not work when I publish a new item. When I unpublish it works fine. But in the Greek menu does not even exists.
In the extra fields vew option all fields are checked.
George- This reply was modified 7 years, 6 months ago by stampgo7.
- July 2011
June 21, 2017 at 10:30 am #1043257June 21, 2017 at 1:33 pm #1043292This reply has been marked as private.June 21, 2017 at 6:22 pm #1043312More details: I just noticed that map stop function when I enter an email on the Extra Field of a new item. It is very strange because the items that allready exists do have emails. Still have not find out the other issue, that in Greek version the map does not exist. To see what I mean find item Stavlos Cottage that I created, go in extra field ad an email and refresh the All in one map page. Then delete the e-mail and refresh again. Also tell me how can I show the map in the Greek menu (ΧΑΡΤΗΣ).
Please help me, I start looking for solution to this problem one week ago and I can not develope this site if I don’t find a solution.
- July 2011
June 22, 2017 at 8:34 am #1043470Hi,
Could you check the info, I can’t access to FTP of you site, and backend account doesn’t have full permission.
Just go to backend >> find & disable this Plugin: Email-cloacking plugin
- This reply was modified 7 years, 6 months ago by Luna Garden.
June 22, 2017 at 10:11 am #1043510This reply has been marked as private.Luna Garden ModeratorLuna Garden
- July 2011
June 23, 2017 at 4:10 am #1043703June 23, 2017 at 5:16 pm #1043875Thanks a lot, I did’nt know that when you copy items you have to add new extra fields.
Kind Regards
GeorgeAuthorPostsViewing 13 posts - 1 through 13 (of 13 total)This topic contains 12 replies, has 2 voices, and was last updated by stampgo7 7 years, 6 months ago.
