August 26, 2015 at 10:52 am #665640
I made a copy of Opening Hours module and I only changed the background to blue (box-background-dark to box-background-primary) and from position-2 to position-3, but the text doesn’t look like the original module. In the image it is the right blue “An?lises Cl?nicas”.
What is wrong?
Thanks in advance.
pavit Moderatorpavit
August 26, 2015 at 11:00 am #665683Hi
When you saved your copied module you should disable your default editor probably it stripped out code
repeat step disabling default editor from global configuration
August 26, 2015 at 11:00 am #672771Hi
August 26, 2015 at 11:00 am #746667Hi
August 26, 2015 at 2:18 pm #672800This isn’t the problem. I disabled the default editor a few weeks ago…
August 26, 2015 at 2:18 pm #746694This isn’t the problem. I disabled the default editor a few weeks ago…
August 26, 2015 at 2:20 pm #672801<em>@rovisco 489238 wrote:</em><blockquote>This isn’t the problem. I disabled the default editor a few weeks ago…
Thanks</blockquote>
Could you send me via Private Message a temp super user account to your backend ?
I will have a look at it
August 26, 2015 at 2:20 pm #746695<em>@rovisco 489238 wrote:</em><blockquote>This isn’t the problem. I disabled the default editor a few weeks ago…
Thanks</blockquote>
August 27, 2015 at 9:35 am #676139The website is not published yet
August 27, 2015 at 9:35 am #746784The website is not published yet
August 27, 2015 at 9:53 am #676141<em>@rovisco 489360 wrote:</em><blockquote>The website is not published yet</blockquote>
Then publish it on a temp domain and we will take a look at your configuration , actually it is impossible to understand what’s happening without access backend
August 27, 2015 at 9:53 am #746786<em>@rovisco 489360 wrote:</em><blockquote>The website is not published yet</blockquote>
October 17, 2015 at 2:45 pm #705603<em>@pavit 489363 wrote:</em><blockquote>Then publish it on a temp domain and we will take a look at your configuration , actually it is impossible to understand what’s happening without access backend</blockquote>
@pavit I already published it. If you don’t mind take a look on this problem. I will sent you in pm the credientials.October 17, 2015 at 2:45 pm #752002<em>@pavit 489363 wrote:</em><blockquote>Then publish it on a temp domain and we will take a look at your configuration , actually it is impossible to understand what’s happening without access backend</blockquote>
@pavit I already published it. If you don’t mind take a look on this problem. I will sent you in pm the credientials. -
This topic contains 34 replies, has 2 voices, and was last updated by rovisco 9 years, 1 month ago.
