Viewing 4 posts - 31 through 34 (of 34 total)
  • pavit Moderator
    #706114
    <blockquote>I already duplicated the code for box-background-primary in template.css, however it looks exactly the same as before.</blockquote>
    evidently your code is wrong , use custom.css file to apply code modifications
    However such type of customization is out of the scope of this support forum , i showed why it is not working you should better verify where is your error since i cannot see any css rule loaded when module class sufffix is added
    Best regards
    Best regards
    rovisco Friend
    #706183
    I moved the code from template.css to custom.css and it works.
    Thanks @pavit !
    rovisco Friend
    #752397
    Thanks @pavit !
This topic contains 34 replies, has 2 voices, and was last updated by  rovisco 9 years, 1 month ago.
