drdig Friend
drdig
- October 2011
March 15, 2012 at 12:13 pm #175018I need help.
After making my website manually in 2.5 and following the quickstart template styles I encounter a problem not solved.Items that are within the module are displayed TECNO HD (which is FREE WALLPAPERS in the original template) to two columns if they are inserted in the top menu.
Should not be, only appear to a column.
Can you tell me what to do to display in two columns, as shown in the first picture?
You can see an example with the first two articles of this section.
thank you very muchThe web is: http://www.altadefinicion.org
Sherlock
- 2478 times in 2162 posts
March 16, 2012 at 8:50 am #443949Hi drdig,
When you clicked to open the first item on this module you would see that it’s opened on a page with two columns layout and if you take a look at the menu section you would see that the actived menu is CINE EN CASA, also in the back-end you have assigned the CINE EN CASA menu to display in a two columns layout.
On the other hand when you click to open the second item on that module you would see it’s opened in a three columns layout and the actived menu is the Home menu item.
That’s the different, the CINE EN CASA menu item is referring to the first item (or referring to the category that contain the item)
to get an item is opened in a three columns layout you just need to create a menu item that refer to it and remember do not assign the Tecno HD module to display under that menu item.I hope you got the ideal and you can do it by yourself !
1 user says Thank You to Sherlock for this useful post
drdig Frienddrdig
- October 2011
March 16, 2012 at 4:50 pm #444015Thanks for the explanation, but do not do what he says and I do not understand English very well Google Translator and the translation is not accurate. Can you help?
drdig Frienddrdig
- October 2011
March 17, 2012 at 10:44 am #444119I tried to do what I explained but I find it impossible.
However, I remind you what I want is to open the article in TWO COLUMS.Can you help?
Sherlock FriendSherlock
March 17, 2012 at 1:34 pm #444137Hi drdig,
can you let me know what you did step by step ?
I am always ready to do it for you but this is simple and I think you should do it by yourself so you can learn from it.n6rej Friendn6rej
- November 2006
- 145 times in 90 posts
March 17, 2012 at 9:50 pm #444216dig please work with Dat on solving this… he’s one of our devs
n6rej Friendn6rej
- November 2006
March 18, 2012 at 1:25 pm #444320alright they say a pic is worth 1k words so lets try this…
as you will see by the arrows, its controlled by the “layout” so, go to your template config-profile and choose “body-left+right” as you desktop layout.
All this is covered in the wiki ( see my signature ) Its a document you really are going to want to become intimately familiar with.
AuthorPostsViewing 7 posts - 1 through 7 (of 7 total)This topic contains 7 replies, has 3 voices, and was last updated by n6rej 12 years, 6 months ago.
