February 9, 2014 at 7:28 pm #194632
I want you to please help me in the following:
1. My JA Bookshop template is not opening from administrator, Template Manager. Please correct the same and also tell what to be done to prevent the same in future.
2. Please tell me how to reduce the width of sidebar1 in JA Bookshop
3. A module placed in top of the template is not displayed properly. You can see in the pic attached. The easydiscuss noification module. (A) The module is bit up then the login module. (B). The drop down notification is not proper.
Please correct the same and tell me how to correct the same in future.
swissa Friendswissa
- November 2011
- 717 times in 572 posts
February 9, 2014 at 7:48 pm #521934For point 1, I take it you’ve upgraded to Joomla 3.2.2?
Please see a recent post I made for someone with the same problem (I think) – http://www.joomlart.com/forums/topic/error-after-updating-to-joomla-3-2-2/
After you’ve applied the fix please check the other problems and might be best to log each problem (along with a url) in separate threads?!
Good Luck!
(Point 3 may be because you are logged in as a Super User. Try it with a normal user account and see if the problem continues.)
February 10, 2014 at 2:05 pm #522045Thank you My Point No. 1 is solved.
But point no. 2 & 3 is still not solved.
Swissa; i have tried the point no. 3 with other users but the problem persists
Please help
swissa Friendswissa
- November 2011
February 10, 2014 at 2:22 pm #522047Glad one problem is solved. As I mentioned above, it might be best to split your remaining problems and post each one separately.
I don’t have Bookshop and to test your system someone is going to have to log in so that they can see the problem – it only happens when you are logged in. I’m not Joomlart support so best if you don’t send me or public post any login details. When you post you can add your details for the support guys to go in and look. While they are there you have lots of javascript errors from your banner advertising. Sorry!
Hope you get it sorted.
AuthorPostsViewing 4 posts - 1 through 4 (of 4 total)This topic contains 4 replies, has 2 voices, and was last updated by swissa 10 years, 11 months ago.
Problem in templates
