  • sincerity Friend
    #177467
    I am not able to use JA Typo in any editors. The sample item will show in the editor when it is selected. I toggle the editor to work with the HTML for making the JA Typo items, like special arrow bullet points, to repeat. But when I toggle back to JCE editor mode, all the new formatting vanishes. What happens is that the JA Typo classes inside the span tag is deleted
    For eg: If this is the span tag for JA Typo <span class=”jatypoclasses”></span>, after toggling back to editor mode, the resulting tag will show just <span></span>. And sometimes, the entire span tag is taken off.
    I am working as Super admin and Text filters are off.
    Now, what I am doing is that I turn off all the editors after copying the span tag with JA Typo classes and then work with the HTML and save it. Then everything is OK until I come back to the same article to modify it with the JCE editor On and save it; all the JA Typo classes vanishes again.
    Please help me out.
    Thanks.
    Hi arjunkrishna,
    Apologies for this late reply. Could you pm me admin account? I shall help you to check it out.
This topic contains 2 replies, has 2 voices, and was last updated by  Saguaros 12 years, 6 months ago.
