  • thanos_gr Friend
    #203089
    Hello
    I have installed JA Google Chart on a joomla 2.5.27 control panel but I have an issue in displaying the chart. More specifically when I am uploading manually a csv file everything works fine but when I am using the URL option the chart is not displayed.Could you help me?
    Thank you a lot
    jooservices Friend
    #556732
    HI there
    Do you mean you are using external URL in configuration and it not works ?
    In this case please check your server is allowed for out connect and php libraries are installed as well.
    Thank you,
    Viet Vu
    thanos_gr Friend
    #556813
    Hi thank you for your replay
    Yes I am using an external URL and the chart is not displayed. How can I check if my server is allowed for out connect? I have a local apache server on Ubuntu.
    Thank you
    jooservices Friend
    #556976
    Hi there,
    # You can check your php error. If it display any errors or fatal errors than you can know it.
    # Please enable curl & curl_ssl
    And yes, of course. Please check your Server firewall.
    Thank you,
    Viet Vu
This topic contains 4 replies, has 2 voices, and was last updated by  jooservices 10 years ago.
