  • harveysd Friend
    #1094022
    I am trying to put a google calendar on page. I add spotlight – choose Text – click on and paste code but as soon as I publish it disappears. What is the correct way to add something like this? I am about ready to cancel my membership for as much headache as ja builder is.
    Firstly, you can go to admin panel of your site and turn off the Default Editor.
    Then add your own code/script of that calendar into a custom HTML module.
    When you edit a page >> add a Spotlight block , in the spotlight, you choose to load module and load the custom HTML module above.
    harveysd Friend
    #1094299
    How do I add the Custom HTML module choice. It is not an option?
    1- Go to admin panel of your site > Extensions > Modules > create a new module with type of Custom module and put your own output content for this module: http://prntscr.com/ikqay4
    2- Edit builder page you want to add module > add a ‘Spotlight’ block > click on the ‘Select Widget’ and configure to show above custom module: http://prntscr.com/ikqbfk
This topic contains 3 replies, has 2 voices, and was last updated by  Saguaros 6 years, 9 months ago.
