victortopper Friend
victortopper
- May 2008
- 2 times in 1 posts
June 27, 2009 at 7:39 am #142284I want to insert the user 7 module over the module user5 “videos-Drive your way”. I note that there is overlap between the two modules. I would like to save on advertising here. Can I have a willingness to help.
URL: http://www.mwinda.fr
Thank you
scotty Friendscotty
- March 2008
- 827 times in 595 posts
June 27, 2009 at 2:28 pm #309230open the banner module you have assigned to User7 and enter _blank as the module suffix.
Your banner pics also need to be reduced in width to fit there.
victortopper Friendvictortopper
- May 2008
June 27, 2009 at 9:13 pm #309254Thank you very much for your reply. Please if you can give me more details how to modify the module
thank you
questbg Friendquestbg
- May 2008
- 339 times in 197 posts
June 30, 2009 at 4:06 am #309495Bonjour Victor
Dans Admin, allez vers le ‘Module Manager’ et ouvrez le module pour vos bannières.
Suite, dans la rubrique ‘Module Class Suffix’ ajouter _blank comme suite:
Chris
AuthorPostsViewing 4 posts - 1 through 4 (of 4 total)This topic contains 4 replies, has 3 voices, and was last updated by questbg 15 years, 5 months ago.
problem insertion module
