test melih
 melih
Viewing 1 post (of 1 total)
  • Gigaparts Friend
    #957192
    Hello
    Problem solved.
    Hi, the correct solution is:
    1. Go to Components, select VirtueMart
    2. Go to Tools, select Update, migration
    3. Go to install tables and if necessary update them to click.
    4. The tables will be created according to the configured language.
    Problem solved!
This topic contains 1 reply, has 1 voice, and was last updated by  Gigaparts 8 years, 6 months ago.
The topic ‘Problem installin languages’ is closed to new replies.
