Viewing 15 posts - 1 through 15 (of 22 total)
  • sintox Friend
    #155151
    I have been able to install the template, however everything looks in one line down, even selecting left or right still puts it at the bottom. I have tried to uninstall and reinstall again, and still looks the same. Is there something I am missing when installing it?
    Don Lee Friend
    #358427
    <em>@sintox 197783 wrote:</em><blockquote>I have been able to install the template, however everything looks in one line down, even selecting left or right still puts it at the bottom. I have tried to uninstall and reinstall again, and still looks the same. Is there something I am missing when installing it?</blockquote>
    Could you decribe the issue on a screenshot or provide me your link & admin account for further checking?
    sintox Friend
    #358498
    <em>@donglt 197820 wrote:</em><blockquote>Hi,
    Could you decribe the issue on a screenshot or provide me your link & admin account for further checking?</blockquote>
    You can view the affects at http://www.bloodyhell.com, I cant post login infomation in a forum.
    I have attached the modular manager photo to see whats turned on and the location.
    1. Problem01
    Phill Moderator
    #358506
    Did you install from the quickstart or just a Joomla install then uploaded the template? I am guessing the latter.
    If it is a new site then maybe best to install the quickstart then re-apply your changes. If not then install Wamp ( http://www.wampserver.com/en/ ) on your desktop and install a copy of the quickstart in that. You’ll then be able to see exactly how everything is setup as the designers intended. It will also allow you to experiment very quickly without all that messing about uploading malarky.
    sintox Friend
    #358526
    How to install from the quickstart? I tried to upload it in joomla but it fails.
    Don Lee Friend
    #358528
    <em>@sintox 197951 wrote:</em><blockquote>How to install from the quickstart? I tried to upload it in joomla but it fails.</blockquote>
    After downloading all elements of the template package, you will have an element named “quickstart”, it inludes Joomla core & JoomlArt template + extensions, extract it and upload all to your root, before doing that, plz move all files and folders of root to another location as a backup. Then browse your root url to install the quickstart.
    sintox Friend
    #358540
    Will not doing this overright any config files for database, etc….?
    Don Lee Friend
    #358542
    <em>@sintox 197967 wrote:</em><blockquote>Will not doing this overright any config files for database, etc….?</blockquote>
    Yes, all you need was embeded in the quickstart, just install it like a normal Joomla installation you will have a site looks like our demo site, but remember to click the “Install Sample Data” button when prompted.
    sintox Friend
    #358544
    Will this install like a fresh install? What will happen with the information I have put into all the database already?
    Don Lee Friend
    #358546
    <em>@sintox 197971 wrote:</em><blockquote>Will this install like a fresh install? What will happen with the information I have put into all the database already?</blockquote>
    Oh, if you have had your database already, it will be overriden, so do not use the quickstart. Could you plz send me your site & FTP account info via PM for further check?
    sintox Friend
    #358573
    I will try and do a full reinstall and see how it works, will update you later after i get everything in. thanks
    Phill Moderator
    #358578
    As suggested earlier, try it all on your local machine using wamp. That way you can work very quickly and if things go wrong it will not affect your live site. It really is a tool you should get to know. Once you’ve used it a couple of time you will wonder how you ever got on without it. Using wamp I can install a test copy of any quickstart on my local machine in under 5 minutes.
    sintox Friend
    #358675
    I have done the install via the quickstart, but now have some other problems.
    1. I created my own poll but does not show up, only the original one shows. (Solved)
    2. Where do I change the bookmarks in the bookmark tab (Solved)
    3. How to make the LOGO graphics bigger
    4. Under video of the day tab, there is a whats new in…. how to change this? (Solved)
    5. I have ALL of the Article turned off when you go to home, the main page is blank, but when clicking on WORLD menu (or any of the others), it now shows all of the WORLD articles that are OFF (or the menu that was selected, world, health, etc).
    6. When I add a new article it comes up to show it has 68 comments (ALL OLD FROM ANOTHER ARTICLE) (Solved) However you need some doc file to be included on what things need to be changes, this forum thing is crazy.
    7. UPLOAD of graphics does not work with your QUICK INSTALL, this quick install is turning out to be a SLOW INSTALL.
    CREATE AN INSTALL DOC TO BE USED WITH QUICK INSTALL and another for MANUAL INSTALL, this will make things way faster, and not require long delay for support and help.
    Don Lee Friend
    #358728
    After installing a new system, we always have many things to discover because it’s new. Just try to figure those issues out yourself first, I think they are not too difficult 🙂 and when face with any stubborn issues, get back and ask me for help 😎
    Phill Moderator
    #358777
    Glad to see you are getting there. The quickstart really is easy and there are many threads detailing how to use it. At the end of the day it is exactly the same as doing a standard Joomla install so I cannot see any way of improving that. If you have any ideas please feel free to make suggestions.
    As for adjusting the logo graphics please be more specific in the size you want the box to be. This requires an adjustment to the css. Learning basic css is quite easy especially if you use the Firefox browser and the excellent Firebug tool. If you tell me the dimensions of the logo you wish to install I’ll detail exactly how and what you need to do.
This topic contains 22 replies, has 3 voices, and was last updated by  Phill 14 years, 3 months ago.
