  • crismary01 Friend
    #160519
    When I finish installing from ‘quickstart’ and after deleting the install folder, website shows:
    Parse error: syntax error, unexpected ‘)’, expecting ‘(‘ in /homepages/3/d357548931/htdocs/plugins/system/jat3/core/common.php on line 230
    I have downloaded package again, reinstalled, but same error.
    Tried installing joomla fist, then the template, same issue
    please help me out, dont now what to do
    Ninja Lead Moderator
    #377901
    I just re-installed this packet and deleted install folder, i never saw error your detail.
    May be you send to me configuration LAMP your system or FTP your system, i help you check on this.
    crismary01 Friend
    #377957
    How can we do it, what do you need?
    #378001
    You can check PHP version: php -v on Linux or create php file with <?php echo phpinfo();?> and then you try to ask the hosting service to upgrade your server to the last version of php, check the issue again.
    crismary01 Friend
    #378182
    Thank you, it worked !!!
    ailyoc Friend
    #379083
    I am having a lot of trouble installing JA Portfolio. This is my 3 day trying to install it and I am at my wits end!
    I have downloaded the zip file and extracted it locally to my computer. I also extracted the template folder locally and uploaded it via FTP to the server. When I try to install it via Joomla, it says please enter package directory.
    Where am I going wrong?
    crismary01 Friend
    #379134
    You dont need to unzip the template. Leave it zipped, then install it from joomla.
    You could also use the started package, and that’s where you will need to unzip that package and FTP to your server to install it. (remember to “install sample data” at the last step of your installation)
    Hope it helps
    ailyoc Friend
    #379866
    crismary, you seem like a helpful person, and I really do need help. Any way I try it, it just says Please enter package directory.
    Can you think of any other potential road blocks?
    #379955
    You can download quickstarts packet here: http://www.joomlart.com/forums/downloads.php?do=file&id=1649 and install to Configuration step click Install Sample Data button you have a pretty site: http://templates.joomlart.com/ja_portfolio/
    domantas_z Friend
    #385118
    then I installing “quickstart” nothing happens. Or I have to install somthing before i installing quickstart?
This topic contains 10 replies, has 4 voices, and was last updated by  domantas_z 13 years, 9 months ago.
