  • solucionesmype Friend
    #936488
    I’m trying installing solidres and it’s impossible.
    Error:
    Warning
    Can’t DROP ‘map’; check that column/key exists SQL=ALTER TABLE #__sr_reservation_assets DROP map;
    Package Update: There was an error installing an extension: com_solidres.zip
    Please I need support with this.
    How did you install this template? Please try to install Joomla package, then install Solidres component and see how it goes.
    #936978
    I did it in that way but it problem appeared me two times. Please how can I fix it?
This topic contains 3 replies, has 2 voices, and was last updated by  Saguaros 8 years, 7 months ago.
