  • ekwade Friend
    #153060
    When we first installed JA Anion, all the templates worked great. We decided we liked light-color as our default.
    So, in the backend, we changed the PROFILE OVERRIDE SETTINGS for All pages And Content Components to light-color in the GLOBAL tab, but it did not produce that particular template as the default on the frontend.
    Now, when selecting light-color from the CPANEL in Anion on the frontend of the website, it will always default to default. Selecting any other theme works fine. We have even tried selecting light-color in the PROFILE OVERRIDE SETTINGS of the GLOBAL tab without seeing any change.
    What are we missing here?
    picsitech Friend
    #351508
    Could be your browser cache. Try setting the template style you want in the backend, then close the website windows and clear your cache. Then go back to the website and refresh a couple times and see if that helps?
    treybraid Friend
    #352627
    Was there a solution to this issue– I too am trying to use that theme and I am having issues as well…
    Trey
This topic contains 3 replies, has 3 voices, and was last updated by  treybraid 14 years, 4 months ago.
