  • alegioia Friend
    #118927
    I’ve purchase the template, but I’ve difficult to configuration Ayax Header Rotator in this template same http://www.saleepepe.it
    I’ve installate the module and I set it in HEADER position, I’ve insert the images in “images/stories/headers”, I’ve create the directory in the exactly path, I’ve insert the photos 1000 x 200 px, I’ve insert the measure exactly in the Module, but I don’t see in the home page the Ayax Header Rotator.
    Now i’ve position the module Ayax Header Rotator in TOP position 9 (http://www.joomlart.com/templates_club/club_portfolio/ja_bellatrix.html) , and this is the result link : http://astra.aleprova.it/
    but i want that the Ayax Header Rotator is in Header, same http://www.saleepepe.it
    Can you help me? :(( Thank you
    Khanh Le Moderator
    #214931
    Ajax header rotator works fine in your site http://www.saleepepe.it.
    alegioia Friend
    #214941
    My site is not http://www.saleepepe.it, but http://astra.aleprova.it/ !
    I want the Ayax rotator works fine there, and in the header !
    You know?
    switt44 Friend
    #215097
    Greetings,
    i’m using Bellatrix template & have published JA Header module
    in user9 position & i’d like to be able to fill the space &/or center the images
    with full screen width option, they appear fine in the wide & std width option.
    just too much grey margin or padding from the background.
    see meanpony.com with JA header here
    … like the examples cited earlier in this thread, using JW Ajax header rotator;
    here the space has been filled to the margins.
    please, any help or advice ?
    NOTE: see attachments for this
    Bellatrix JA Header solution
    by JA member swemmel 🙂
    now shown here & in the previous meanpony sample link >>
    –unzip the index.php & rename the css file from .txt
    to template_css.css –backup 1st, then load to the proper directories, set permissions as needed (755)
    Thank You again, joomers, JA staff
    & especially swemmel for this excellent customization
    sWitt @ meanpony
This topic contains 4 replies, has 3 voices, and was last updated by  switt44 17 years, 9 months ago.
