October 29, 2011 at 2:38 pm #170175
Hi, I have a problem with JA Contentslider, appears the following error line
/templates/ja_portfolio/html/mod_jacontentslider2/default.php on line 47thanks
TomC ModeratorTomC
- October 2014
- 3155 times in 2495 posts
October 29, 2011 at 4:05 pm #422335<em>@enricmr 279644 wrote:</em><blockquote>Hi, I have a problem with JA Contentslider, appears the following error line
/templates/ja_portfolio/html/mod_jacontentslider2/default.php on line 47thanks</blockquote>
That is not an error, that is a location.What is the particular error you are experiencing?
October 30, 2011 at 9:15 pm #422465TomC ModeratorTomC
- October 2014
October 31, 2011 at 3:54 am #422483<em>@enricmr 279819 wrote:</em><blockquote>Hi Thanks for your interest. Attached image of the error</blockquote>
Per your picture, you’re using JM Organis. As such, you cannot integrate a Joomla extension into a Magento based theme.
October 31, 2011 at 8:05 am #422512Hello Tom, the template is Ja Portfolio. The post template example is JM Oganis . This is the link: http://www.alquileresgranollers.com/k2-categories/categories-view/drupal/item/112-jm-oganis
TomC ModeratorTomC
- October 2014
October 31, 2011 at 2:06 pm #422595<em>@enricmr 279882 wrote:</em><blockquote>Hello Tom, the template is Ja Portfolio. The post template example is JM Oganis . This is the link: http://www.alquileresgranollers.com/k2-categories/categories-view/drupal/item/112-jm-oganis</blockquote>
What is this website you are creating – and why are you using the JoomlArt name?October 31, 2011 at 2:34 pm #422598Hello, I have only loaded the template to see if it suits my project. Maybe I rushed to get help. I just like to know how to remove that error linia.
TomC ModeratorTomC
- October 2014
December 11, 2011 at 9:23 pm #429215Hello Tom, Thanks for asking. I have not solved the problem. In the end I installed another component
TomC ModeratorTomC
- October 2014
December 11, 2011 at 10:10 pm #429220<em>@enricmr 288566 wrote:</em><blockquote>Hello Tom, Thanks for asking. I have not solved the problem. In the end I installed another component</blockquote>
Sounds good . . . and I do apologize for the late response to your question.Hope the component you chose is working out as you hoped it would !!!
AuthorPostsViewing 10 posts - 1 through 10 (of 10 total)This topic contains 10 replies, has 2 voices, and was last updated by TomC 12 years, 11 months ago.
Problem JA Contentslider 2
