test melih
 melih
  • albonello Friend
    #1091890
    The error is listed below
    This redirect url is not allowed, you should change the "Allowed domains for the redirection via the module" parameter from the AcyMailing configuration page to "localhost|10.0.0.102|10.0.0.50|10.0.0.29|10.0.0.170|10.0.0.66|10.0.0.101|dev.joomlart.com|demo.joomlart.com|downloads.joomlart.com|109.73.231.18" to allow it or set it to "all" to allow all urls
    • This topic was modified 6 years, 11 months ago by  albonello.
    Pankaj Sharma Moderator
    #1091990
    I can not see the error on your site now.
    It’s from the Acymil component, you need to configure the extension as given in the documentation here .
    If you do not want to use it, you can disable or remove the component from Extensions > Manage in Joomla admin.
This topic contains 1 reply, has 2 voices, and was last updated by  Pankaj Sharma 6 years, 11 months ago.
