  • jppfm Friend
    #129115
    My left menu the links are too much to the left and i want to put them like the second image. What should i do?
    #251318
    Hi jppfm !
    It”s best if you send link of your site !
    jppfm Friend
    #251379
    No problem…
    http://www.transbrasilvirtual.org/
    #251638
    Hi jppfm !
    You open template_css.css file in templates/ja_larix/css folder and find following code section at about 1054 :
    a.mainlevel {
    background:transparent url(../images/a-mainlevel-bg.gif) no-repeat scroll left bottom;
    color:#403C3A;
    display:block;
    font-weight:bold;
    padding:5px 0pt 6px 15px;
    text-decoration:none;
    width:90%;
    change into :
    a.mainlevel {
    background:transparent url(../images/a-mainlevel-bg.gif) no-repeat scroll 15px bottom;
    color:#403C3A;
    display:block;
    font-weight:bold;
    padding:5px 0pt 6px 25px;
    width:90%;
    continue , find following code section at about line 1072:
    a#active_menu.mainlevel {
    background:transparent url(../images/a-mainlevel-hover.gif) no-repeat scroll left bottom;
    color:#EE9600;
    font-weight:bold;
    change into :
    background:transparent url(../images/a-mainlevel-hover.gif) no-repeat scroll 15px bottom;
    color:#EE9600;
    font-weight:bold;
    jppfm Friend
    #252457
    thanks ill trye that.
This topic contains 5 replies, has 2 voices, and was last updated by  jppfm 16 years, 7 months ago.
