February 24, 2011 at 10:21 am #160639
The template with megamenu or menu works fine with “Public Status”, but no work when I log a “Spécial” user or a “Author” user (for exemple). The items in menu, doesn’t appear!
It works with other Template Beezer2 !
Have you got the same problem ? Or it’s just because a Beta version ?
Thanks for you reply 😉
February 25, 2011 at 10:16 am #378424Dear,
We doesn’t get that problem. Please try reinstall and check, if it still has problem, let open the ticket http://support.joomlart.com/index.php?/Tickets/Ticket/View/65581 and update your site access information then our devs will diagnose and get it fixed asap for you.
Regards,
February 27, 2011 at 11:41 pm #378698Hello,
i have the same problem, Megamenu only works with “Public” but not with any other access levels.February 28, 2011 at 11:31 pm #378945I tried on another Joomla installation but here it also doesn’t work, do you have any other helps?
Thanks a lot, Markus
dunglq Frienddunglq
- March 2010
- 12 times in 13 posts
March 1, 2011 at 7:13 am #379007<em>@sandtarnfarbe 224504 wrote:</em><blockquote>I tried on another Joomla installation but here it also doesn’t work, do you have any other helps?
Thanks a lot, Markus</blockquote>
Hi,I tried to install JA PURITYII for joomla 1.6 and create some user, then logined in front and, but mega menu still works well
Could you give me details url to check problem?
fade2gray Friendfade2gray
- July 2010
- 2 times in 1 posts
March 1, 2011 at 12:22 pm #379071I don’t know if this is of any help – I notice, with Puritty II for Joomla 1.6, that the MegaMenu works ok if just fade is selected or just slide is selected, but if they are selected together the menus cease to function.
March 3, 2011 at 6:45 pm #379528Hello,
my testdomain is j16.wvv-schiedsrichter.de – how you see in the screenshot a user in loged in, megamenu and the left menu should have the same content, but in the mega menu you only can see these items who are public … the items that are only for registered users are not shown.Thanks for your help!
dunglq Frienddunglq
- March 2010
AuthorPostsViewing 8 posts - 1 through 8 (of 8 total)This topic contains 8 replies, has 5 voices, and was last updated by dunglq 13 years, 8 months ago.
Problem JA Purity II 1.0.0 Beta Megamenu no work with ACL
