July 1, 2014 at 7:32 am #199319
hi, on the site I had to install ja slideshow lite because JA Slideshow Module does not fit all devices, in fact if I visualize the site on ipad, the slide is cut. So I was advised to install ja slideshow lite but it is not as wide as the width of the template, but it is closer. I inserted this code in custom.css file. Ja-slideshow.
.ja-slideshow .container {
padding: 60px 10px 0 10px;
width: auto;
}but unfortunately nothing has changed
Can anyone suggest anything else?
JA Slideshow Module is located in the home page http://www.isap-piemonte.it/
while ja slideshow lite is located at this linkhttp://www.isap-piemonte.it/index.php?option=com_content&view=categories&id=92&Itemid=714
TomC ModeratorTomC
- October 2014
- 3155 times in 2495 posts
July 1, 2014 at 3:01 pm #540815Can you be a bit more specific as to exactly how you want your JA Slideshow Lite to display – height/width ??
July 3, 2014 at 8:39 am #541047the problem is that the home page
http://www.isap-piemonte.itI used ja slideshow and goes well with regard to the width but if I visualize the site on ipad image with the word gets smaller and is cut and not good. Under welfare courses at this link
http://www.isap-piemonte.it/index.php?option=com_content&view=categories&id=92&Itemid=714I used ja slideshow lite and fits but the width is not the same as the slide of the homepage despite the image is the same size.
They suggested I write a custom.css file in which to place the code. ja-slideshow. container {
width: auto;
}but the slide has not changed width.
I have a monitor at 1920×1080
Can you help me solve this problem? Thank you
Adam M ModeratorAdam M
- May 2014
- 1271 times in 1235 posts
July 8, 2014 at 2:03 am #541457Hi,
Please open file your_root_folder/templates/ja_biz/css/custom.css (if you don’t have this file, just create a new one), then add this code :
.t3-slideshow .main-container {
margin: 0;
}Save your file and recheck.
July 10, 2014 at 7:37 am #541827perfect, thank you very much, now it works correctly but there is still a small problem, on your smartphone between the slide and the text below is a lot of space. I enclose a picture
- May 2014
July 11, 2014 at 9:51 am #541961Hi,
The main slideshow should be disabled in Extra Small layout (the same way we implement demo site). I have logged in to your site back-end and update this part for you, please recheck.
AuthorPostsViewing 6 posts - 1 through 6 (of 6 total)This topic contains 6 replies, has 3 voices, and was last updated by Adam M 10 years, 3 months ago.
problem ja slideshow
