  • paulafprint Friend
    #127191
    Hello, I would like to use the JA SLWI module in the template JA BARITE. Is this possible? In download area have only for joomla 1.5, and my site use barite 1.0.
    bigrk Friend
    #244163
    Moved to proper forum so you can maybe get an answer from users of the same template.
    Menalto Friend
    #244182
    You can try the following module that i have attached here. This module is for 1.0.xx version of Joomla.
    And then open the template_css.css file and add this at the very bottom:
    /* SLWI */
    .ja-slwi-container {
    width: 100%;
    .ja-slwi-container h3 {
    color: #545454 !important;
    font-family: "Lucida Grande", Tahoma, Arial, Helvetica, sans-serif;
    font-size: 100% !important;
    line-height: normal !important;
    margin: 0 !important;
    padding: 7px 10px !important;
    .ja-slwi-container h3 span {
    background: none !important;
    .ja-slwi-text p {
    color: #666666;
    margin: 0;
    padding: 0 10px;
    Then you take the mootools file attached here and replace with the one you allready have in the js folder of the template.
    When you have done that please setup the module as you wanna use it and check that it works fine.If it looks strange ttry to put -no in the module suffix field.
This topic contains 3 replies, has 3 voices, and was last updated by  Menalto 16 years, 9 months ago.
