Viewing 15 posts - 1 through 15 (of 22 total)
  • mpiper Friend
    #168496
    Hello
    I want to use a 3rd party module called mod_slidergallery but when i published in pages with ja_tabs published the modules shows like photo1 (see attach). In all other pages (with no ja_tabs) the modules shows good. This happend only in IE. In Firefox looks ok.
    My url : http://www.sportorama.gr
    Michael
    1. explorer_error
    2. firefox_ok
    mpiper Friend
    #412405
    Anyone ???
    Manos Moderator
    #412409
    I guess this is a JS conflict (although i can’t see the error on Error Console) so if i was in your place i might try to use ja content slider to achieve this 😉
    P.S. You created a heavy page that needs a lot of loading time ( The page has a total of 222 components and a total weight of 3408.2K bytes) this might also be an issue you know ?
    Manos
    mpiper Friend
    #412416
    222 components ? where do you see them ?
    Manos Moderator
    #412418
    Well… you could use YSlow ( on FF ) to check this!
    mpiper Friend
    #412786
    I dont want to show image content. So ja content slider is not good. I want to show pics from directory with slide.
    mpiper Friend
    #412856
    Anyone can help ?
    mpiper Friend
    #413030
    Please help ?
    mpiper Friend
    #413147
    Is there anyone to help us find a solution about this conflict ? I test the module mod_slidergallery is other templates and working good.
    Manos Moderator
    #413167
    Well it’s not always that easy ( or even some times it’s not possible ) to make all modules work together on a web site.
    I guess that a solution would be to disable the mootools call on this module but i am not that good with this, so maybe an other member will be able to help you!
    Thank you for your patience.
    Manos
    n6rej Friend
    #413168
    <em>@mpiper 267858 wrote:</em><blockquote>I dont want to show image content. So ja content slider is not good. I want to show pics from directory with slide.</blockquote>
    ja-slideshow is designed for that. http://www.joomlart.com/joomla/templates/ja-ores might take a serious look @ that.
    mpiper Friend
    #413193
    But in firefox the module shows correctly. Something is going on the template. Please help
    mpiper Friend
    #413195
    <em>@n6rej 268325 wrote:</em><blockquote>ja-slideshow is designed for that. http://www.joomlart.com/joomla/templates/ja-ores might take a serious look @ that.</blockquote>
    Yes i know that module. But is only for slide pics or articles. I want the pics to pop up when user click on them
    n6rej Friend
    #413355
    ok, the fact that firefox displays it fine and IE don’t at least is comforting to know… IE has serious issues.. we all hate it , its always gotta have special treatment 😉
    push this up to ta ticket and we’ll see if we can slap IE back into shape for you
    mpiper Friend
    #413564
    Hello i place a ticket but the answer was that the module faults. I test similar module and the result is the same. Conflict with ja_tabs.
    Can anyone help.
    I need to show images from a directory with popup window. Can anyone suggest other way ?
This topic contains 22 replies, has 4 voices, and was last updated by  Blaine 13 years, 3 months ago.
