Viewing 7 posts - 16 through 22 (of 22 total)
  • Blaine Friend
    #413635
    Hi mpiper,
    If the error is only happening in IE, try to remove this code:
    <style type="text/css">
    .clearfix {display: inline-block;}
    </style>
    in the index.php file
    I will be anxious to hear if this resolved your issue!
    mpiper Friend
    #413647
    <em>@Blaine 268893 wrote:</em><blockquote>Hi mpiper,
    </style>
    I will be anxious to hear if this resolved your issue!</blockquote>
    I cannot find that code. Please tell me the exact path of index.php
    mpiper Friend
    #413907
    Any solution ?
    Blaine Friend
    #413931
    I am so sorry I have not gotten back to you till now, but my computer crashed and I am just now back up and running today.
    Let me explore the template files and see exactly where the code is. Unfortunately with my computer having so many issues the past 2 months, I have not had the opportunity to go into any JA templates and review the files.
    I would suggest that the code may be found in the template.css files or the ie.css files as well.
    Thank you for your patience.
    Blaine Friend
    #413938
    I found it!
    Override head.php, you should copy head.php file from plugins/system/jat3/jat3/base-themes/default/blocks and paste it in templates/your _JAT3_template/blocks and make changes in this file.
    Let me know if you have it from here.
    mpiper Friend
    #414415
    <em>@Blaine 269252 wrote:</em><blockquote>I found it!
    Let me know if you have it from here.</blockquote>
    I found head.php in plugins/system/jat3/jat3/base-themes/default/blocks but in the destination folder there is no head.php to overwrite. Anyway i paste it in the directory but nothing happend.
    Blaine Friend
    #414545
    Hi mpiper!
    Please see this terrific tutorial by pascm on this subject!
    Thanks!!
This topic contains 22 replies, has 4 voices, and was last updated by  Blaine 13 years, 3 months ago.
