  • pedrer Friend
    #193161
    Hello
    I have on my page http://www.inacer.com JATab module, and into him..in the Foto seccion i have 3 photos ( of the template quick) and dont working the Japopup plugin
    when i clic over the imagen, is opened but in the same webpage…. but not in the japopup.
    pedrer
    pedrer Friend
    #516163
    this are the imagen of the error
    1. errorpoppup
    2. jtabpopup
    Nazario A Friend
    #516262
    Hi pedrer,
    Please PM me with Admin account of your site, so that I can check and help you out.
    Regards,
    Nazario A
    pedrer Friend
    #516312
    thank NAzario, i send to you a PM
    thanks
    pedrer
    pedrer Friend
    #516313
    Nazario… i see that on the webpage of inacer.com where before appear the module jatabs …now appear this code…
    do you make some change?
    thabks
    pedrer
    1. jatabserror2
    pedrer Friend
    #516351
    Hello Nazario…some solution?
    thanks
    Nazario A Friend
    #516375
    Hi Pedrer,
    I have just checked your problem. This error comes from the load order of the plugin. JA Popup is loaded after JA Tabs. I have just changed the order for you.
    You can see as this image:
    <em>@pedrer 403114 wrote:</em><blockquote>Nazario… i see that on the webpage of inacer.com where before appear the module jatabs …now appear this code…
    did you make any changes?
    thanks
    pedrer</blockquote>
    JA Mendozite template is using JAT3 cache. You should disable System Cache in back-end.
    Let me know if this helps
    Regards,
    Nazario A
    1. popup3
    2. popup2
    3. popup1
This topic contains 7 replies, has 2 voices, and was last updated by  Nazario A 11 years ago.
