June 16, 2015 at 9:22 am #207450
My guess is there is som conflicts.
I hav added a mootools switcher on/off script. You will find it in the pluginsection it you search “moot”
Something is wron. Please help us.
Br
Ken
Adam M ModeratorAdam M
- May 2014
- 1271 times in 1235 posts
June 17, 2015 at 8:55 am #574401Hi @newpo,
First, there’s a JS conflict in your site and I’m afraid that debug this part is beyond our support scope. But you can try to temporary disable any 3rd party extensions in your site to see which one is the cause of your problem.
In addition, make sure that you don’t use single / double quote in tooltip description field and recheck.
June 19, 2015 at 1:39 am #574684Hi
Thanks for the answer.Can i hire you to find and solve this conflict for us. And in case of yes, what will it cost?
Have a nice day
June 19, 2015 at 1:39 am #641028Hi
Have a nice day
June 19, 2015 at 1:39 am #739692Hi
Have a nice day
June 19, 2015 at 1:54 am #574687and…
If this might be a solution. Where would i implement it
// load jQuery, if not loaded before
if (!JFactory::getApplication()->get(‘jquery’)) {
JFactory::getApplication()->set(‘jquery’, true);
// add jQuery
}June 19, 2015 at 1:54 am #641031and…
// add jQuery
}June 19, 2015 at 1:54 am #739695and…
// add jQuery
}Adam M ModeratorAdam M
- May 2014
June 19, 2015 at 4:11 am #574723Hi @newpo,
The code above is used to check if jQuery has been loaded or not and call the jQuery lib accordingly, but your problem comes from jQuery and Mootools conflict.
Mootools is not used in Joomla! 3.4.x anymore but you’re using FLEXIcontent which need Mootools to be enabled and it cause a JS conflict as you can see.
- May 2014
June 19, 2015 at 4:11 am #641067Hi @newpo,
- May 2014
June 19, 2015 at 4:11 am #739731Hi @newpo,
This topic contains 10 replies, has 2 voices, and was last updated by abdulsamad 7 years, 4 months ago.
