  • 7of9 Friend
    #204499
    I discovered a problem with VM orders. I created a menu item showing Virtuemart Orders List. I created a user and made an order. While still connected I click on the List Orders menu (At bottom left): http://www.dogbows.gr/en/order-status and there are no orders. FYI: After the order submitted I could see the order if I click on the VM order message. Also the order is visible in Joomla Back End. Also if you are disconnected (logged out) at the Front End, there is a text box you can fill up, with the order number and this way you can search and see the order.
    Please advise.
    Thanks in advance.
    I couldn’t see the list order menu item on your site.
    I also tried to create a new menu item type of VM List Orders in my local site >>> login from frontend with Super admin account and still see the order list.
    1. listOrders
    7of9 Friend
    #562408
    Hi Saguaros,
    The problem has to do with the order list when logged in as a shopper, not as admin.
    This is were the menu item is:
    This is how the list looks out (It’s blank, as you can see):
    However, as you can see, the shopper in question has an order (This is the page called by the link after posting the order):
    Thanks in advance.
    1. OrdersListMenu
    2. OrdersListPage
    3. OrderDetailsPage
    Did you try to switch default template (JA Hawkstore) to default Joomla template like Beez / Protostar? and see how it goes?
    7of9 Friend
    #562620
    Hi @saguaros,
    I switched to Beez 3 and the problem is there as well.
    7of9 Friend
    #562696
    I found the solution here: http://forum.virtuemart.net/index.php?topic=128415.0 and I post it here too, so if anyone else has the same problem to be able to fix it easily.
    Just replace the file view.html.php at: components/com_virtuemart/views/orders with the one I attach and problem solved. I suppose they will fix it in a later version, however 3.0.6 has this problem. Maybe Joomlart could resolve it as a template override for the time being in the template, until it’s resolved by VM stuff.
    Take care you all. 🙂
    1. view.html_.php
This topic contains 6 replies, has 2 voices, and was last updated by  7of9 9 years, 10 months ago.
