vsds Friend
vsds
- July 2009
- 3 times in 1 posts
August 21, 2009 at 10:13 am #143612Hi
I have a problem when I list the articles of a section. In firefox runs ok, but in IE8 the widht of the table is displayed incorrect
attach capture
ps5t0ck5 Friendps5t0ck5
- October 2008
- 33 times in 11 posts
August 25, 2009 at 11:46 pm #315272If you still have this problem we could do with more info to help solve it – what does it look like in IE7 (what it should look like) and a link maybe?
vsds Friendvsds
- July 2009
August 26, 2009 at 9:24 am #315300Hi
it runs ok under Firefox and in previous versions to IE8.
If I enabled “view of compatibility” in IE8, then it displays ok. But this is not a good solution.
I cannot also activate the plugin “System – IE8 Compatibility” because then this template does not appear correctly in all the versions of the IE
The problem is that the table of the articles (default) does not occupy the width of the page (view the screenshot of my first message)
- October 2008
August 26, 2009 at 8:03 pm #315381Have you tried the fix suggested elsewhere on the forum of inserting the following into the head of your index.php?
<meta http-equiv=”X-UA-Compatible” content=”IE=7″ />
vsds Friendvsds
- July 2009
August 27, 2009 at 8:55 am #315438<em>@ps5t0ck5 142092 wrote:</em><blockquote>
<meta http-equiv=”X-UA-Compatible” content=”IE=7″ /></blockquote>
is indifferent if I have this tag or no, because the issue persists.
regards
- October 2008
August 27, 2009 at 6:59 pm #315480I have tested a section list – which didn’t have the appearance of yours – did you make changes? The test was ok without compatibility or ie plugin.
If you meant list of articles in category – which looked like yours, this was also fine on the test…
All I can suggest is that you clear the cache and purge expired items – if still no luck then check that the table in the relevant template file is set to width 100% (files found in the components/com_content)
Sorry can’t help more.
vsds Friendvsds
- July 2009
August 28, 2009 at 8:32 am #315514Hi
I did not change anything of the template
I have the last version of joomla 1.5.14. Are you tried with this?
<blockquote>
All I can suggest is that you clear the cache and purge expired items – if still no luck then check that the table in the relevant template file is set to width 100% (files found in the components/com_content)</blockquote>I’ll try it
vsds Friendvsds
- July 2009
August 28, 2009 at 8:45 am #315517<em>@ps5t0ck5 142226 wrote:</em><blockquote> if still no luck then check that the table in the relevant template file is set to width 100% (files found in the components/com_content)
.</blockquote>
sorry, which file?
- October 2008
August 28, 2009 at 2:33 pm #315561Hi vsds
I have upgraded to Joomla 1.5.14 and the version of JA Corona is 1.4.
I would check these according to the menu item that you have set up (whether section blog or category)
/yourwebsitefolder/components/com_content/views/section/tmpl
or
/yourwebsitefolder/components/com_content/views/category/tmpl
If they are fine you could also double check that you have no modules active for the right position that have nothing to show.
A link to your site might help.
Anyone else got any ideas?
vsds Friendvsds
- July 2009
August 29, 2009 at 6:58 pm #315679AuthorPostsViewing 10 posts - 1 through 10 (of 10 total)This topic contains 10 replies, has 2 voices, and was last updated by vsds 15 years, 4 months ago.
Problem listing articles of the section – IE
