  • hutcruchi Friend
    #172117
    hi all
    im using the ja_t3 default template and created the mega menu using the video tutorial with the child menus..
    i have one problem:
    when i check with fire bug the css of my menu – the parent item and his child items are defined asa the same menu level..
    so when i want to remove the border for example from my chiled menu items its automaticly removes it from the main menu items of my web site..
    for example the main menu is: 1 2 3 4
    and 2 menu item is a parent for: a b c child items
    and c menu item is a parent for: I II II chiled items.
    (all of them are defined as text seperators except the parent item “2” how is defined as category menu item)
    i want to remove the borders of a b c chiled items but then it removes also from 1 2 3 4 main menu items..
    only the : I II II menu items are defind as level 1 menu item and all the rest are defined as level 0… so i have 1 level missing??
    im using joomla 1.7
    thanks!
    Blaine Friend
    #431308
    I hope this helps you with T3
    There is an excellent T3 guide also.
    hutcruchi Friend
    #431397
    thanks ill look it up
This topic contains 3 replies, has 2 voices, and was last updated by  hutcruchi 13 years ago.
