  • thomase Friend
    #149280
    Hi there,
    i have the problem, that installing the JomBlog-Modules I always get some bubbles in the text. Is there a Module Class Suffix (or something else) to resolve this problem! The text should be shown without these bubbles.
    Thanks, Thomas
    1. screen-capture
    Dear thomase!
    it has so many solutions to fix this issue, i give your the solution with the Module Class Suffix paramter
    1) pls add the following style into the template.css file:
    li.nobullet{
    background:none !important;
    2) you put the ” nobullet” text ( note: has a blank character befor this text ) in the Module Class Suffix paramter
    good luck
This topic contains 2 replies, has 2 voices, and was last updated by  Saguaros 14 years, 9 months ago.
