lg21 Friend
lg21
- July 2012
- 9 times in 1 posts
July 24, 2013 at 3:54 pm #189202Hi all, I have a problem in the form ja-tab2 does not work properly as you can see from this page.
http://www.quotidianodigela.it/dai-comuni/dai-comuni-news/butera
What could be the cause?
pavit Moderatorpavit
July 24, 2013 at 5:19 pm #500057Hi
Did you checked if the ja_popup plugin is published ?
lg21 Friendlg21
- July 2012
July 24, 2013 at 5:36 pm #500058is the plugin is active ja_popup
July 24, 2013 at 5:54 pm #500059<em>@lg21 382067 wrote:</em><blockquote>is the plugin is active ja_popup</blockquote>
Then also the System – JA Tabs plugin is published ?
If you still encountering problems with it you can send me a PM with a temp super user account so i can have a closer look to it
- November 2014
- 3854 times in 3563 posts
August 9, 2013 at 11:08 am #501766<em>@lg21 382055 wrote:</em><blockquote>Hi all, I have a problem in the form ja-tab2 does not work properly as you can see from this page.
What could be the cause?</blockquote>
Thanks for your pm me. I have fixed the directly on your site.
1) JA Tabs plugin: Order JA Tab need to load before JA T3 framework
2) JA Extensions: You need to use JA Extensions Manager Component to upgrade latest version from Joomlart product.
3) Both of problems in JA Comment are solved now.
Please check it again, let me know if it helps
lg21 Friendlg21
- July 2012
August 10, 2013 at 4:12 pm #501811Thanks but the problem ja tab I did not understand how to solve it.
When it relates to the updates I ever downloaded components, modules and plugins and upload them via ftp
Moreover, the problem inherent in the screen to select the author of the article remains unchanged
Greetings
- November 2014
August 12, 2013 at 2:20 am #501877With the problem JA Tabs plugin, I have changed its ordering from Plugin Manager, see the screenshot
AuthorPostsViewing 7 posts - 1 through 7 (of 7 total)This topic contains 7 replies, has 3 voices, and was last updated by Ninja Lead 11 years, 4 months ago.
