  • melvine Friend
    #683276
    I bought a module for display the financial stocks here : http://finance.wis.ro/
    When I put the module on Home 1 position ( who isn?t the place is belong) the system of mouseover works well. See the picture below.
    But if I put the module on Banner 1 position ( where is belong), the mouseover doesn?t works anymore .
    Did something block the mouseover system in the sidebar ?
    Have you an idea how I can fix that ???
    Thank you for your help
    Best Regards
    jooservices Friend
    #683349
    Hi there
    Would you mind bring your site online than i can check it.
    You can try disable js compress first.
    And see if any js errors around.
    Thank you,
    Viet Vu
    jooservices Friend
    #748307
    Hi there
    Thank you,
    Viet Vu
    melvine Friend
    #683350
    My apologies Viet Vu , it’s my fault. It was a problem of parameter “X Offset” and “Y Offset”. The graph was appeared outside the window in fact but now it’s ok. All work well.
    But it’s saturday and yet you are here for answer me. Again you are really the BEST Joomlart and you Viet Vu;)
    melvine Friend
    #683382
    melvine Friend
    #748308
    jooservices Friend
    #683383
    Glad to hear that
    As developer we have no life 🙂 always stay online with computer
    Thank you,
    Viet Vu
    jooservices Friend
    #748309
    Glad to hear that
    Thank you,
    Viet Vu
This topic contains 8 replies, has 2 voices, and was last updated by  jooservices 9 years, 3 months ago.
