  • danaos Friend
    #184307
    I have just installed JATiris for Joomla3.0
    There is an error on categories and My Cart: “Strict Standards: Only variables should be assigned by reference in /home/marksmob/public_html/modules/mod_jshopping_categories/mod_jshopping_categories.php on line 26”
    Also the same on line 39, 42, 47, 34, 44
    Also in MYCART: “Strict Standards: Only variables should be assigned by reference in /home/marksmob/public_html/modules/mod_jshopping_cart/mod_jshopping_cart.php on line 22. Also the same in 26
    Anybody can help?
    swissa Friend
    #480947
    I haven’t installed J3 version of Tiris but what version of Joomshopping is installed? You can see it on yourdomain.com/administrator/index.php?option=com_jshopping&controller=info
    If it isn’t version 4.x then this would be your problem. If it is 4.0 I suggest you try updating (through Joomshopping not Joomla) to version 4.1 and see if that cures it. Update files are HERE.
    Hope that helps!
    danaos Friend
    #481012
    Thank you for your help. I have downloaded and installed the upgrade but nothing changed.
    Anyway, thanks again
This topic contains 3 replies, has 2 voices, and was last updated by  danaos 11 years, 11 months ago.
