  • sugiarto Friend
    #137451
    Hi all,
    I just installed quick start (ver 1.5), it is ok, it is diplay like on the demo.
    Then I installed from a scratch. I created 1 article on frontpage as a test.
    There are a problems (attach is a screen shoot of my web)
    1) Frontpage didn’t display image article’s correctly. Image is displaying on left corner of the top
    2) Article title style and creation date style is not like on the demo.
    I have looked on quick start but didn’t find the cause, can anyone helps me to solve these problems?
    Thanks in advance,
    Regards,
    Sugiarto.
    1. Image
    sunrise Friend
    #287995
    Hi sugiarto,
    The easiest way is to install the quickstart, and then keep that installation and work from there, adding your own material and then yo ucan unpublish the things you don’t need from the quickstart.
    damian Friend
    #288000
    Go to Your Menu > Main Menu > Home
    Parameter System > Page Class Suffix type : _fp
    sugiarto Friend
    #288002
    Ah, so that’s the problems.
    Thanks a lots,
    Sugiarto
    chaosnoir Friend
    #288087
    I found this topic to be helpful, as I had the same issue, and fixed it without the headache, but I do have a question as to why the user guides don’t contain all the information for people who don’t install from scratch (quickstart).
    Even though I’ve followed the user guide for this template, that explains how to format the slide shows, I still have issues with my nav bar, but there is no information on formatting the JA Menu section, among other things.
    weather290 Friend
    #299916
    Hi, I’m having this problem on JA Quartz. I changed the page class suffix to _fp, but it changed it to something I don’t want.
    I’m trying to add an image below the body paragraph. I attached the original problem (untitled.jpg) and then I attached an image of what it did when I typed _fp in the page class suffix (untitled2.jpg).
    Please help! 🙂 Thanks.
    1. Untitled
    2. Untitled2
    weather290 Friend
    #302122
    Anyone? I’m still having this issue.
    tranaee Friend
    #302701
    Delete the article image that generated the thumbnail insert it again and you’ll be ok..;)
    joeluvny Friend
    #309096
    <em>@sunrise 107982 wrote:</em><blockquote>Hi sugiarto,
    The easiest way is to install the quickstart, and then keep that installation and work from there, adding your own material and then yo ucan unpublish the things you don’t need from the quickstart.</blockquote>
    i also have the same probleem and tried using the quick start installation instead of starting from scratch but i got the same results. if i use a different template everthing works fine. if i use the JA Quartz template then the frontpage article image displays in the upper left corner os the screen
    Does anyone have a solution?
    tranaee Friend
    #309098
    Delete the image you used in the article and use another one.. then everything will be ok.. Somehow you changed the dimensions of it and the thumb generator is getting crazy then..:)
    joeluvny Friend
    #309100
    Thank you very much for the _fp suffix i add it and now the front page look like it should but only in Fireforx. The front page content display is offset to the right and floating over the right column in IE8, Crome and Safari. Does anyone have a solution for this problem?
    Thank you
    joeluvny Friend
    #309101
    Thank you very much for the _fp suffix i added it and now the front page look like it should but only in Firefox. The front page content display is offset to the right and floating over the right column in IE8, Chrome and Safari. Does anyone have a solution for this problem?
    Thank you
This topic contains 12 replies, has 7 voices, and was last updated by  joeluvny 15 years, 6 months ago.
