  • sugiarto Friend
    #137548
    Hi all,
    I build my web from a scratch. I have a slideshow and 2 custom modules on my web. I put slideshow position on ja slideshow, custom modules on ja tabs position and ja tabs module on user5.
    Slideshow is ok, but on user5 position, appear these messages
    {jatabs type=”modules” animType=”animNone” style=”” position=”top” widthTabs=”120″ heightTabs=”30″ width=”100%” height=”auto” mouseType=”click” duration=”1000″ colors=”10″ module=”ja-tabs” }{/jatabs}
    On Quickstart, tab is ok, what wrong then? How to fix it?
    PS: I used Joomla 1.5 on localhost.
    Thanks in advance.
    Regards,
    Sugiarto.
    damian Friend
    #288475
    Enable your ja tabs plugin
    plutoww Friend
    #297214
    Hello, im having the exact same problem. Tried enabling the ja tabs plugin, but when I went to the Plugin Manager I couldnt find it. I then tried to install it but was told that it was already instald.
    Please help,
    emonzon Friend
    #297306
    <em>@plutoww 119319 wrote:</em><blockquote>Hello, im having the exact same problem. Tried enabling the ja tabs plugin, but when I went to the Plugin Manager I couldnt find it. I then tried to install it but was told that it was already instald.
    Please help,
    Thanks</blockquote>
    go into your plugins folder via ftp or cpanel, whatever your hosts use. Look for /plugins/content/jatabs
    Delete the folder and re-install in Joomla cpanel.
This topic contains 4 replies, has 4 voices, and was last updated by  emonzon 15 years, 9 months ago.
