  • georgios Friend
    #152277
    Hello
    Thanks to your intervention wirebank plugin works.
    But I want to implement a more simple operation (without redirection):
    1: the advertiser control
    2: he says he pays by check or wire transfer
    3: after validation takes note of the address and bank details
    4: Upon receipt of the check or wire transfer manually I confirm the purchase order that has its credits
    What do you tip and how do I use?
    Thank you
    Anonymous Moderator
    #348984
    <em>@georgios 185196 wrote:</em><blockquote>Hello
    Thank you</blockquote>
    Dear Georgios,
    I am afraid that currently, we could only offer technical support for as-is usage of all our templates/products only. Customized codes are beyond the support range.
    However, you can easily find an expert to have the project done via a reliable freelance site: Joomlancers.com, another network of JoomlArt. I personally recommend as thousands of projects have succeeded on the site.
    Let us know if we are of any further assistance.
This topic contains 2 replies, has 2 voices, and was last updated by Anonymous 14 years, 5 months ago.
