  • victortopper Friend
    #145735
    With the new template TELLIN JA III, I have a problem displaying photo. In the images directory I have the directory rezised for pictures but I do not understand this error message
    “Warning: mkdir () [function.mkdir]: No such file or directory in / var / www / vhosts / mwinda.org / subdomains / test site / httpdocs / modules / mod_jabulletin / jaimage.php on line 182”.
    Here is the link of my test site. http://site-test.mwinda.org permissions on files and directories are at 755 I had made to 777 was the same thing.
    Thank you for your help
    Hello victortopper!
    please click to “Report to Jira” Button ( it’s on the bottom-right postion of each thread) and choose Assignee is “Tien Ha Cong”, and give me FTP and Administrator Account in there.
    I will work immediate after accepted your information.
    victortopper Friend
    #322514
    Hello Mr. Tienhc,
    I could not Trover button “Report to Jira” to send you the ftp and administrative codes.
    thank you for specifying the location
    Hello victortopper!
    You see this screenshot:
    http://www.joomlart.com/forums/attachment.php?attachmentid=6135&stc=1&d=1257325852
    or you send your information via PM.
    thanks
    victortopper Friend
    #322530
    I just send you the codes on your private message
    Phill Moderator
    #322531
    This is a typical permissions or safe mode problem. Are you able to install other components?
    Hello victortopper!
    this is the problem with php version, the __construct function does’nt work on your site.
    i have quick fix and upgrade the jaimage.php file on our extensions.
    i add this block code in this file:
    [PHP]
    function JAImage(){
    $this->__construct();
    [/PHP]
    now, your site is working well.
    victortopper Friend
    #322558
    Good evening Mr. Tienhc,
    What version of php to make this template? This function you rejouterà which directory do I find?
    Thank you
    Hello victortopper!
    oh, that’s a bug in our extension, we have improved the thumbnail generable function for some extensions such as ja new, ja new2, ja jabulletin…ect, they have released along ja templates a week ago.
    I’m very luck when found and fixed the issue happening on both your site and our extensions. Many thanks!
    i made my changes with files as follow:
    modulesmod_janews2jaimages.php
    modulesmod_jabulletinjaimages.php
    victortopper Friend
    #322562
    Thank you a lot of work you do for the Joomla community. I am happy to have contributed to this problem. I would like to know, I would like to Fançais while the top menu that is home, date feature, etc. .. Member which files are needed for the modification
    thank you
    victortopper Friend
    #322634
    Hello Mr. Tienhc,
    I come to you for information. I would like to change the header of the homepage in French, which files should be changed?
    example: Thursday, November 05th, Home, World, Last update: 04:16:07 AM GMT
    Headlines: Curabitur Suspendisse nibh urna laoreet, consequat Eget hendrerit tempus porttitor, feugiat Proin enim nibh id nulla auctor, aliquam Vivamus Phasellus fames and
    Morbi nunc nibh venenatis Vestibulum libero, * Features, Feature 10 Things you MUST know about Teline III Find out more … * Tool
    Tool are: o Increase font size
    o o Default font size Decrease font size * Member etc. ..
    Best regards
    Anonymous Moderator
    #322729
    Hi victortopper
    You can refer this thread: http://www.joomlart.com/forums/topic/how-to-modify-date/
    I think it will help you to solve this issue.
    victortopper Friend
    #323046
    Good evening,
    I would like to use this site “You are here: Home” or of “HEADLINE” to put a drop down menu, is it possible to modify the template if yes which module or file to edit.
    Thank you
This topic contains 13 replies, has 4 voices, and was last updated by  victortopper 15 years, 2 months ago.
