jcsanjurjo Friend
jcsanjurjo
- May 2012
- 2 times in 1 posts
October 21, 2012 at 12:31 pm #181581Hi all, we’re experiencing problems surfing megamenu between the diferent menu levels. The problem in Chrome is low, but in IE is dramatic.
When pointing with the mouse to any item on Menu Level 2 which has song items, automatically appears in the right a new cascade window with the song items (Menu Level 3). That’s ok. The problem is when you try to slice the pointer from level 2 to level 3, because often, in IE very often, when the pointer leaves level 2 to entry level 3, the whole level 3 cascade window disappears.
Find attached a screenshot, and even you can check it on my site
Thanks for your help
jcs
- November 2014
- 3854 times in 3563 posts
October 22, 2012 at 9:29 am #470741I tried to test with your mention but i could not duplicate your mention, i only saw your site loading very slow, please check it again.
jcsanjurjo Friendjcsanjurjo
- May 2012
October 23, 2012 at 9:16 am #470869<em>@Ninja Lead 343210 wrote:</em><blockquote>I tried to test with your mention but i could not duplicate your mention, i only saw your site loading very slow, please check it again.</blockquote>
Hi @ninja Lead, I know the site loading is slow, is a test environment, but please, note that if you slice the mouse slowly from level2 menu window to level3 menu window, in the moment the pointer reaches the border of level2 menu window, level3 menu window disappears.
Please go to this menu CLIENTES (lev1) > CASOS DE EXITO (lev2) > CUNE…. (lev3) set the pointer on CASOS DE EXITO (lev2) and try to slice slowly the pointer to CUNE…(lev3) and you’ll realise as the level3 menu window disapperars.
jcs
- May 2012
- November 2014
October 25, 2012 at 11:27 am #471092I fixed the problem mega menu on your site. Please check it again.
- May 2012
AuthorPostsViewing 6 posts - 1 through 6 (of 6 total)This topic contains 6 replies, has 2 voices, and was last updated by jcsanjurjo 11 years, 11 months ago.
Problem pointing Megamenu with the mouse between Cascade Menu Levels
