March 9, 2017 at 6:20 am #1016623
Hello guys,
ran into a problem. After almost a year without any problems, my site began to experience some weird issues. It began a few weeks ago when my hosting provider claimed that the site was using excessive bandwidth. They upgraded me to a higher bandwidth package and the site began to work really slow and I was unable to login to the administrator panel to add new articles and when I was I couldn’t post them because the text editor field disappeared (see attached image). After more complaining they said that there is nothing wrong on their side and that the developer of the template is at fault, which lead me here. 🙂 Any ideas or suggestions?
March 9, 2017 at 6:40 am #1016631Hi
You have to set the error report to Maximum from Global configuration to check the error.
Also check the default editor in Global configurations and make sure the editor plugins are enabled on site.Hope it helps
March 9, 2017 at 6:51 am #1016638Thank you! What puzzles me is the fact that nothing has been changed in the setting. Everything was working fine one day and the next it doesn’t work.
March 9, 2017 at 7:19 am #1016651You are welcome!
Maybe you did some changes or updates that create the issue. You can check the issue with my suggestions.Regards
March 9, 2017 at 9:13 pm #1016881I tried. It didn’t work. Hosting company claims it’s an issue with developer.
March 10, 2017 at 1:35 am #1016905This reply has been marked as private.March 10, 2017 at 4:33 am #1016975This reply has been marked as private.March 10, 2017 at 4:37 am #1016976This reply has been marked as private.Pankaj Sharma ModeratorPankaj Sharma
March 10, 2017 at 5:18 am #1016979Hi
JA Teline is not admin template? how can i post an article on admin panel using JA teline?
Its Joomla template on admin side.
Here you can see the issue if from Editor http://prntscr.com/ei4mmo
You can change the editor from global configuration and check it again.
I do not have permission to check it on admin side.AuthorPostsViewing 9 posts - 1 through 9 (of 9 total)This topic contains 8 replies, has 2 voices, and was last updated by Pankaj Sharma 7 years, 6 months ago.
Problem Posting An Article
