Hi, when i use the rsgallery2 it load the prototype.js and it conflict with slidemenu.js and the top menu slide menu not appair… i tried also drop menu and other but its same… i want use the lightbox function that have rsgallery… if i rename prototype function the slidemenu appair but obviously lightbox not work… How i can fix this??
There was also another problem, that rsgallery and slidemenu load same javascript motools and for this lightbox not work… but i fixed deleting the motoolsv1.11 version of ja corona. Rsgallery and corona have same 1.11 version. But this is fixed.
The problem then is the prototype, because lightbox work, but when it work, menu disappear. I want that menu work and also lightbox… can someone help me?
