February 5, 2008 at 5:41 am #125489
First of all – I LOVE the template. With some modification I can get this functioning similar to Teline (maybe). Great layout.
The slider is gorgeous but don’t know if I can use it. Looks like Apple web site. Awesome programming and style who ever did this.
PROBLEM WITH LEFT HAND COLUMN REMOVAL:
I don’t really want the LEFT HAND column but I can see how some would want it.
If I move items from the LEFT to the RIGHT – the structure falls apart and the RIGHT items are on the bottom. It looks like they are pushed over. I don’t know if I can fix this myself or not. Maybe if I work on the <div> tags or the css tags I can get this working.The ONLY WAY IT DOES WORK is to have it set up either way.
1. NO left hand column but on the right side ONLY Massbot and Masstop – NOTHING in Right1 or Right2. Then it works fine
1. NO left hand column but on the right side ONLY RIGHT1 and RIGHT2 and NO Massbot and Masstop.
When I have either only one group or the other – the alignment is fine and it works and looks great.
It would be nice to have both but this might work okay for me.
pamela
Michael Casha FriendMichael Casha
- 119 times in 1 posts
February 5, 2008 at 5:51 am #238219If you don’t enable anything in the LEFT column then it will disappear,
othweise have you got a screenshot and/or a live site url?
February 5, 2008 at 1:00 pm #238253http://wacono.pamelajayawardena.com/
On the front page and the typography page both masstop and massbot + right1 and right2 are being used. On other pages right1 and right2 are not there so you can see it works okay without them.
I just don’t understand PHP well enough and how to create my own templates to fix this.
Khanh Le ModeratorKhanh Le
- November 2013
- 203 times in 131 posts
February 5, 2008 at 2:33 pm #238257This is a problem when calculating the show/hide column. To fix it, open file ja_vars.php, go to line 36 and change to code:
Error code:
if ($ja_right==2) {
Change to
if ($ja_right>=2) {
February 5, 2008 at 9:05 pm #238291Made the change and it works like a dream! Thanks!
I really love this template –cssyeah Moderatorcssyeah
- June 2006
- 121 times in 81 posts
February 7, 2008 at 7:55 am #238447Hi all my friends,
I have just updated all packages ( template and quickstart ).
February 7, 2008 at 8:11 am #238448<em>@trungch 39586 wrote:</em><blockquote>Hi all my friends,
I have just updated all package ( template and quickstart ).
:D</blockquote>
Sounds great thanks trungch! -
This topic contains 7 replies, has 4 voices, and was last updated by Michael Casha 16 years, 10 months ago.
