  • imaxenio2293 Friend
    #183107
    How to change the results page of k2 filter? I really displays the results on the same page where the finder module inserted.
    As I can mostar results on a new page by pressing the search button?
    MoonSailor Friend
    #476367
    Hi imaxenio2293 ,
    K2 Filter using layout “Generic” of k2 component for results search page. Now, you can’t change layout of search result.
    If you want change search layout, you can :
    To change the generic.php overrides, follow our instructions below:
    Step 1: Copy file: generic.php from: /components/com_k2/templates/ to: /templates/YOURTEMPLATE/html/com_k2/
    Note: If the folder /html/com_k2/ does not exist, please create the folders.
    Step 2: Customize the file: generic.php as you wish the layout of search result page with JA K2 Filter module to be.
    1. generic
    2. edit-code
    rsystems Friend
    #476493
    Hi MoonSailor,
    What do I have to change in file generic.php to display search results with following specs:
    – Divided in 3 columns, unlimited item rows to bottom of page
    – Item image 50x50px, article title, first 20 words from article as description
    – Read more button
    MoonSailor Friend
    #476495
    Hi rsystems,
    You need to customize K2 layout. In this case, I can’t support.
    Our support scope is limited to bug fixing and helping users get demo site alike setup.
    imaxenio2293 Friend
    #476513
    Thanks but I have done that already, but my problem is that when you press the search button does not generate a new page to see the results, but these are shown on the same page where it is published in module position contentbody
    imaxenio2293 Friend
    #476522
    The k2 filter search results shows me always on the index page or the page where the module is inserted, but I can not generate a new page where the results show.
    I want to generate a new page to display the results. Is that possible?
    rsystems Friend
    #476661
    <em>@MoonSailor 350939 wrote:</em><blockquote>Hi rsystems,
    Our support scope is limited to bug fixing and helping users get demo site alike setup.</blockquote>
    Hi MoonSailor,
    I understand your point of view, but I don’t understand why JA makes a Search and Filter module, without the possibility to setup the display of the search results…. I can’t use the module now :((
    Regards, Maarten
    rsystems Friend
    #476669
    Feature request: possibility to select K2 category, in which the layout of the search results output is defined.
    MoonSailor Friend
    #476716
    Hi @rsystems,
    – About customizing K2 layout “generic.php” file, i will write tips for it and back to you when it’s done.
    <blockquote>
    </blockquote>
    Thanks for raising this feature up, we will discuss about this with our dev team.
    @imaxenio2293 : pls send PM to admin and url your site. I need the same to detect problem.
    rsystems Friend
    #476757
    Super, looking forward to it.
    Thanks!
    MoonSailor Friend
    #476846
    Hi imaxenio2293,
    When I checked your site, i think JA K2 Filter runs as normal. Search result returns with “component/jak2filter/?Itemid=101&xf_11=0&xf_12=0&xf_13=0” – it’s layout of k2 component (generic.php).
    <blockquote>
    </blockquote>
    Now, it’s not possible.
    rsystems Friend
    #477881
    <em>@MoonSailor 351227 wrote:</em><blockquote>Hi @rsystems,
    @imaxenio2293 : pls send PM to admin and url your site. I need the same to detect problem.</blockquote>
    <em>@MoonSailor 351404 wrote:</em><blockquote>Hi imaxenio2293,
    Now, it’s not possible.</blockquote>
    Hi MoonSailor,
    Could you take a look at this or write instruction please?
    Is this something that could be added into future update? It would make the plugin so much better!
    Much appreciated! 🙂
    Kind regards, Maarten
    mrneil Friend
    #482135
    +1 on adding the option to output results in the same format as the chosen category view. In my case 4 column + small image only. See screen grab.
    1. K2_category_view
    MoonSailor Friend
    #482295
    Hi mrneil,
    Sorry, I don’t really get what you mean here. Could you please be more specific so that I can offer the proper help?
This topic contains 14 replies, has 4 voices, and was last updated by  MoonSailor 11 years, 10 months ago.
