  • midcult Friend
    #139941
    Firstly, great templates and support guys – very glad I paid for the service.. I have a few questions on further developing Teline 2 and I cannot find answers when searching your forums.
    1) How do I keep the menu section highlighted (e.g. as if I clicked on a menu section) when using Joomla 1.5 in SEF mode? Whenever in SEF mode, I click on a menu item and the menu item is not highlighted. I have PHP experience, just need to know which file to edit.
    2) Which is the best extension/module for article comments with Teline 2? I heard about JOM Comment but I’d rather use !Joomla Comment cos its free (I hear cries of cheap bast*rd!)..
    Finally, how does the Teline 2 template distinguish between the frontpage, section/menu page and the article? Which files?
    Many, many thanks in advance.
    Mike
    midcult Friend
    #301403
    I used sh404SEF – which worked perfectly when using Teline 2 and Joomla 1.5. All menu highlighting and links worked perfectly. Make sure you turn off Joomla system SEF and Htaccess before using this component.
This topic contains 2 replies, has 1 voice, and was last updated by  midcult 15 years, 7 months ago.
