January 1, 2018 at 3:37 am #1084047Hi Burly Nerd,
Did you install JA Focus with Quickstart package or install it manually into an existing website? Pls make sure that you set JA Focus as default template first, then check the category settings again, that Fields tab should appear.
Share me the credentials of your site if problem still persists, I will help you to check.
Burly Nerd FriendBurly Nerd
- November 2017
January 1, 2018 at 5:22 am #1084057No, this is not QuickStart. I followed all of the instructions for a manual build of a page similar to the demo. No fields tab.
Saguaros ModeratorSaguaros
January 1, 2018 at 6:19 am #1084058Kindly share the credentials of your site, I will check for you.
- November 2017
January 1, 2018 at 1:00 pm #1084096That will have to wait until I have another site that I try to build manually, or if somebody else tries to build a JA Focus similar-to-demo site from the instructions.
January 2, 2018 at 3:40 am #1084178Pls let me know when your site is online so that I can check for you.
January 3, 2018 at 2:52 pm #1084532Hi,
It’s weird, I’ve shared with the team for further checking on this and will get back to you soon.
January 3, 2018 at 3:25 pm #1084546thanks
January 5, 2018 at 3:22 am #1084935Hi guys,
When you install template manually, pls follow these below steps to create ‘Colors’ fields as our demo site:
1) Go to Admin panel > Content > Fields >> filter the fields by Category (by default, Joomla displays fields filtered by Articles): http://prntscr.com/hw9aac2) At this point, create a new Fields called Colors with type of List (list) and fulfill list of values for this Colors field: http://nimb.ws/RVDUkY
Remember to assign this ‘Colors’ field to the categories you want to have this custom field: http://prntscr.com/hw9ce8
3) Now, open the settings of category, that ‘Fields’ tab should display there: http://prntscr.com/hw9ctb
We’re sorry for any confusion caused. The documentation team will update the guide of this template pretty soon.
Pls give it a try and let me know if you need any further helps.
Cheers!
January 11, 2018 at 11:16 am #1086326Thank you very much
This topic contains 10 replies, has 4 voices, and was last updated by nabilamsery 6 years, 10 months ago.
The topic ‘Problem Setting Category Color’ is closed to new replies.
