test melih
 melih
  • maillard71 Friend
    #175611
    hello everyone
    I’m having a problem with the shopping cart.
    when you add a product to cart, it appear in the shop cart module on the left menu.
    If i click on anothe category or homepage, it says that the shopping cart is empty…and after not..
    The problem appear with ie 9, seems ok with ie 8.
    I really need help on this one!
    Thanks in advance.
    #447238
    Hi maillard71,
    I think the problem mostly is related to the virtuemart setting itself, could you post here your url where the issue is seen ?
This topic contains 2 replies, has 2 voices, and was last updated by  Sherlock 12 years, 10 months ago.
