  • brieuc Friend
    #121708
    Hi, I try to put Slideshow in my website but he don’t show..
    I do so the manual instruction (position 28, …. see image). But i found a problem, i can’t organize my modules (see img 2). It’s probably the problem, can you help me ?
    Thx
    1. capt
    2. capt2
    swemmel Friend
    #225627
    brieuc;22670Hi, I try to put Slideshow in my website but he don’t show..
    Thx
    You can not order the modules, because in poition slideshow there is only 1 module placed.
    Do you have a live url for us?
    Kind Regards,
    Peter
    brieuc Friend
    #225631
    In position slideshow there’s 1 module?? I don’t know.. can you explain more? My url is http://www.decolore.com/joomla (it’s in construction but you can see..)
    swemmel Friend
    #225632
    brieuc;22676In position slideshow there’s 1 module?? I don’t know.. can you explain more? My url is http://www.decolore.com/joomla (it’s in construction but you can see..)
    If you will send me a pm with user-id/password for you website (admin-rights needed), I will try to fix it for you.
    Kind Regards,
    Peter
    brieuc Friend
    #225639
    Ok i send you detail for enter in my website. I hope you can do that! 😉
    swemmel Friend
    #225646
    brieuc;22685Ok i send you detail for enter in my website. I hope you can do that! 😉
    Your slideshow is working now. What I did was, publish something in the top-module position.
    Kind Regards,
    Peter
    brieuc Friend
    #225648
    ok Peter thanks a lot!!! i’m very happy , thanks too for your reactivity !
    Best Regards
This topic contains 7 replies, has 2 voices, and was last updated by  brieuc 17 years, 5 months ago.
